Version 2.7 final
Talked with @Quadzilla Power today about the 2.7 beta -> final move.  We both decided that the boost offset feature was causing more trouble than it was worth.   we have reverted how the late model trucks read  boost to using the 13 psi offset.    The way the truck drives is perfectly fine if idle psi is 0, 1, or 2 psi.   It is annoying but trying to solve the issue just complicates things more than most are willing to work with.
the mpg trip and mpg meter +  improved handoff stayed in place.
I know I have said this a few times, but I think V2 tuning is wrapped up and done done.    Now onto V3 :whistle:
:shifty:
kidding of course.
Edited by Me78569
  • Replies 44
  • Views 12.8k
  • Quadzilla Power
    Quadzilla Power
    If you built tunes on the 2.5 profile (the standard V2 Dodge 1998-2002 v2.5) profile then they should still be there when you update the vehicle profile to version 2.7. If you are moving from the Quad
  • Quadzilla Power
    Quadzilla Power
    Unfortunately there isn't a real good way to fix that other than removing the data. If you have access to your tunes now you can export them all to yourself, delete the app, redownload (or just clear
  • Did someone say V3?? We're waiting patiently Nick...
My boost is off by 3psi, the Iquad is showing 3psi less than the boost gauges, checked with two different gauges, and also checked with two different map sensors.  The boost gauge rises to 3 psi  then the iquad starts to show pressure,  then by 20 psi the iquad catches up and is accurate.
How do I find out which version 2.7.1 or 2.7.7 I have?  The adrenaline was updated at DAP's shop on Feb. 28/2018.
If your box was updated in DAP's shop on Feb. 28, 2018 then you most likely have the latest V2.7.7. If you want, you can look at the build date sensor and tell us what that says. Its easiest to do that in the data-log section at the bottom of the list.
Regarding the boost pressure offset. A mechanical or dedicated gauge is always going to be more accurate than the MAP sensor that we use. For boost pressures below ~16psi we use what the truck thinks the boost is based off the MAP sensor and math done in the ECU. Sometimes the internal barometer works and reports it correctly, sometimes it doesn't. Above 16psi or so, we take over the calculation based off the output voltage. In the legacy tuning, the adrenaline always calculated it based off MAP voltage.
Thanks for the map sensor info/explanation.  The number in the data logger is  20180208
You have the latest tune loaded then. You should be good to go.
And by the way, the internal barometer I was referring to is inside the ECU, not in the Quad, that would just be too handy if we had one of those. Biggest problem with that though is that we are in a sealed system so I don't think the pressure could transfer inside the enclosure very easily.
