APPS, ECM, Alternator? Surging and Bucking under load and idle.
- Replies 10
- Views 4.6k
GSP7 3 posts
Colafson 3 posts
Mopar1973Man 2 posts
dripley 2 posts
There is a right up in the articles section about ECM rebuilders folks have had success with. It is in 24v/engine/electrical. I can't figure out how to post a link on this tablet. You need to be caref
I was on a long drive home across Canada for Christmas and at the end of my drive my truck started bucking a little bit, at first I thought it was just running a little rough so I limped it the last 50km's to my parents. Look into it a little and saw the APPS reset and tried that.
The next day I hop in to drive it to town and it idles fine when I am warming it up for 10min, I start to drive it and I can tell something isn't right. Bucking at any engine load, Surging up to 2500rpm when I put the clutch in, sometimes to the point it seems like I was going to break a motor mount or run away. (Never any dead pedal though, I could put to the rug and she wouldn't hesitate). As all this is happening I am trying to pull off the road and I get a CEL. I scanned immediately and got codes "P0123, P0380, P0382, P0606, P0602". I have never had a code thrown on this truck and I check quite frequently, once a week or so.
So I start with the cheap problem, buying the Timbo APPS and installing that according to the provided instructions, then clearing all the codes. Start the truck and it idles but is a little jumpy (75-150rpm increases). I start driving down the problem is definitely still there bucking/surging like before. On the way back up the block back home it throws a CEL for "P0123, P0382".
Today I started going through all the wiring and checking continuity and voltages between the APPS, ECM and PCM. I got to "Step #11" in the "P0123 Troubleshooting Thread". Continuity and Voltages seems fine up until "Step #11" where I have 0.0V between Ground and "No.23" on "PCM Connector C1" when the truck is running.
Tomorrow I am going to do "Step #14" and check continuity between "PCM C1 No.23" and "ECM No.28" as well as pull and clean all the grounds and check the Alternator for AC again with a Oscilloscope.
As I said I am in Canada and we can't get the $2100 ECM from the Stealership as they have been discontinued and awaiting production again. Has anyone had any luck with NPD Diesel's Remanufactured and Flashed ECM's starting to look like my only option for replacing mine if it come down to that.
All the After Market parts in my signature have less than 100,000km on them.
Video I took today.
http://www.npddiesel.com/cummins-1-plugs-ecms
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/obdii-error-codes_94/p0123-apps-sensor-signal-voltage-too-high-r43/
Edited by Colafson
