I have a 2001 4x4 with a six speed transmission and 200000 miles.  The truck is a one owner,  I bought it from my Father in law and is completely stock.  I have been around the truck since it was bought new.
The truck was really strong until around 190000 miles when the VP44 went out.  The pump has been replaced with a unit from a local re builder in Memphis TN.  Since the VP44 replacement the truck has not been the same.  I drove it around 200 miles yesterday and it averaged 11MPG.  I have owned 24 valve Dodge trucks in the past and have always gotten high teens on fuel mileage and had much more power.
When I am accelerating thru the gears I cant manage more than 5 pounds of boost until the truck gets up to 2100 rpm and it is like you flip a switch and the boost raises quickly to around 22 pounds.  If I am cruising on the freeway around 70 MPH I have around 10 pounds of boost and the exhaust temp is around 900 degrees.  I am unable to produce more than 5 pounds of boost under 1800 RPM.
The truck has never had any injector work done that I know of. The engine runs and starts perfect it just does not have any power.  I cleared all the codes from the computer with a Matco scanner and drove the truck.  I had a P0216 code re appear but I don't have any of the symptoms related to the VP44 going out unless the low power and fuel mileage are related as the engine runs perfect.
 Any advice on where I should start looking to find my problem?  Don't know if it has any bearing but I cant make the truck produce any black smoke.  I know black smoke is not necessarily a good thing but all of my other trucks in the past have had black smoke.
I have made some up grades to the truck since I have been reading on this forum,
Gauges,  Fuel Pressure,  Boost Pressure and Exhaust Gas Temp.
Fuel Pump,  Fass 95 GPH.  I have 17 pounds of pressure while driving it down the road.  The stock pump showed to have around 11 pounds at an idle and 7 pounds under wide open throttle.
I am not looking for a power monster only to get back to where the truck was before the VP44 replacement.
  • Replies 58
  • Views 11.4k
  • Dieselfuture
    Dieselfuture
    I could be wrong but, it sounds like you might have something going on with your 5-volt Loop, oil pressure sensor is on that Loop if it's shorts out internally it will create these similar problems. J
    I would keep your pair of ECM and PCM. If the other donor truck is a matching truck with same options then I would take the ECM and PCM for spares.
    You could just unplug it for a test drive. The gauge will not work but it'll prove the short idea.
The fuel pressure stays on 15psi.  I have a new fass fuel pump installed on the truck.
I have watched your videos and completed a AC noise test and it was within specs.
The will not start when engine is warm is back.
I am really lost.
I hooked the truck up to a Matco Scan Tool this afternoon and drove it around 50 miles.
I had it on the live scan mode while driving.
The voltage to the ECM would go between 12 volts to 9.88 back and forth.  When the truck was at its lowest power point I was only showing 9.88 volts.  Could this be a ground issue?
The MAP was pretty much all over the chart also.  My boost gauge would show 10 psi and the scanner would go between 0 to 10 back and forth.  I also had 6 pounds of boost showing with the truck not running.
Im going to pull the alternator off in the morning and have it tested.
Are there any more things I can check in live scan mode that may help narrow my problems?
Passenger battery terminal. All ECM, PCM and VP44 ground is right there.
Then if you want to get crazy and go for the ground mod.
Cummins ISB does some weird math to figure boost pressure. So I wouldn't consider this too bad might be part of it still.
Ok,  pulled the alternator and had tested at the local Autozone.  Test was good.  Going to borrow Fluke multi meter to check AC noise again.
If AC noise checks ok will move on to the ECM and VP grounds.
Thanks for all the advice.  Will advise if i find my issue.
One thing i noticed yesterday is throttal response is good until about a quarter of the way when accelarating. After that the truck pretty much will go flat until it reaches around 2000 rpm and the boost starts raising up.
Also i noticed the oil pressure guage moves to around 40 psi when the key is on.  Not sure if this matters just something I seen yesterday.
Edited by BMC330
Alternator noise is .025 vac on fluke meter.
Going to OHM the throttle position sensor now.
Better off watching the live data from the ECM. Ohm values don't mean much. You should see 0 to 100 prevent throttle signal. Rising smoothly. This can be done without driving.
On the live data we found the TPS all over the chart.  Looked like watching a heart monitor when I put it on the graph mode.  Replaced the TPS and we are getting the same results.
The TPS will read constant when only about 1/8 of the way depressing peddle.  The truck seems to run fine at that point.  If you mash the peddle any further the readings go all over the chart.
I am only getting one code and it is a PCM fault/3.
I have checked the grounds and found no issues.  I also unplugged the wiring going to the ECM to check for corrosion but it looked new.
I could be wrong but, it sounds like you might have something going on with your 5-volt Loop, oil pressure sensor is on that Loop if it's shorts out internally it will create these similar problems. Just my guess not saying you need to start changing sensors for no reason.
PCM abnormal is all i am getting.
You might check the CCD bus for issues. The APPS sensor is shared by both ECM and PCM. If the CCD bus is goofy it might dirty all data. Remember the PCM is the primary computer the ECM is secondary.
Graph of apps sensor percent.  Wide open is 65%
We unplugged the first wire bundle closest to the drivers side and apps is smooth.  The graph looks perfect between apps percent and apps voltage.  And we are getting 100 percent on apps.
Not sure where to go from here.
Edited by BMC330
I'm going to have to lean on the idea that you've got a damaged PCM. You saying you already getting a PCM abnormal error. Then where you unplugged the PCM the APPS signal returns to normal. Like I said I would have to lean on the idea PCM is malfunctioning.
You might want to read this article too.
PCM is what we are thinking also.  I have a friend who has a truck we may be able to borrow a PCM from to see if our symptoms go away.  If he will allow us we are also going to get the ECM.
I will advise when we have the PCM changed.
Ok.  Im not sure if it has all the options as my truck as mine is loaded and the other is a work truck.  I will order a new one and go from there.
Thank you.
