Stereo/Aux Input question
I found this article here about the Aux input, but it has me a bit confused....
when I look @ these pictures, the radio that is being modified looks exactly like mine, so Im assuming that its the same one as the only other one I have seen is a single height radio, not like the one in the article above.
Also the article mentions, " I did see a write-up on here for the Infinity system, but not the cd/cassette Chrysler radio".  This has me confused.  I have had the door panels off of my truck & it does have the infinity speakers in the doors  with the Amps bolted to them.  I assumed that this meant that the radio is also an infinity as well.  is this not the case?
it appears from the pictures in the write up, that he is soldering the wires for the jack to the pins on an input connector that is on the back of the radio.  is that true?  If it is true, cant I just plug into that connector that is on the back of the radio??
thanks
Bob
  • Replies 8
  • Views 2.7k
  • gipperkid
    gipperkid
    If you don't want to wire you radio. There is a company that does this mod to factory radios. 1 Factory Radio. We sell all our OE radios to them for this reason.
If you have an infinity headunit this write-up wont work for you.  You will need to find the writeup for the infinity head unit.
I didn't just soldier to the back pins,  I spliced the wires into the tuner output to the amp, then used the 1/8" headphone jack to complete the radio if the jack is unused.  If you don't cut the pcd leads then you will get audio from the radio and form the aux input.
Is that infinity write up here on this forum?
does the infinity radio look exactly like yours?
thanks
Bob
Don't remember where I found it anymore,
No clue.
Gotcha.  Thanks.
I guess the first thing I need to do is remove the radio and find the part number.
Bob
Hmmmmmmmmmm I wonder how well that works?  I might have another use for that......
thanks
Bob
thanks
Bob
14 hours ago, Mopar1973Man said:
Another solution is an FM transmitter. This is how I do it in my old 1996 Dodge Ram since its an aftermarket CD deck.
https://www.amazon.com/Doosl-Universal-Wireless-Transmitter-Adapter/dp/B018QN4INM/ref=sr_1_3?ie=UTF8&qid=1522242049&sr=8-3&keywords=fm+transmitter
Works good. Very short range though typically in the cab it works the best if on the seat or on the dash. At floor level kind of OK. I've got a old one that run on two AAA batteries and it will work for about a week on a set of battery as long as you remember to turn it OFF when it park the truck. That's the bad part batteries...
