Engine swap 99 to a 2001
- Replies 6
- Views 4.7k
Merl 3 posts
Mopar1973Man 1 post
Me78569 1 post
jlbayes 1 post
I've made huge mistake. Put a 01 24 v replacing 99 24 v. I knew there was no Crank sensor but didn't know about tone ring. Is there any type of kit that can correct this. #6 cylinder started knocking and it's a 53 block 346000 miles. Didn't want to rebuild. Came across a wrecked 01 low mileage. I didn't do my home work and now have a big problem. The truck started several times but will not start now and no tach. I still have the wrecked truck ecm and pcm but is's a automatic and my truck is a manual. Is there any type of kit to correct this, change cranks, switch ecm & pcm and flash add the tone ring.
