2000 to 2002 Steering upgrade
Hello guys I'm not sure if this has been discussed on this forum before or not. I am considering a steering upgrade for my 2000 Ram 2500. This thread is too help anyone out if they ever want to try this to. Id like to know if anyone else here has done this specific kit ill mention? The kit is from a 4th gen truck and was made specificly for upgrading third gens steering. SOmeone on Cummins Forum bought this kit for a second gen and found out that it was a awesome bolt on upgrade for second gen trucks to! Now I read that trucks with stock 16 inch wheels the stud on the end of the tie rods will hit the wheel so you have to grind off an eighth of an inch or so. I don't believe this works for 98 and 99 trucks but correct me if I'm wrong. Anyways the part # for the kit is #51122362af and that's a mopar part number. Hopefully I can try this upgrade soon but in the meantime id like to find out more about it and possibly create an article when I'm done to help others. I think you can get this kit straight from the dealer for around 350$ which is a very fair price if the upgrade is as good as mentioned. Everyone knows that our steering kind of sucks. I think that big tires and leveling kits make it worse too. This converts the steering to a t style instead of the factory y style steering.
Edited by Marcus2000monster
  • Replies 176
  • Views 28k
  • I worked in a Western Auto for my first job at the tender age of 14. Never touched any over sized wheels and tires back in 1967. To young to operate the tire changer. But Loyd the boss man helped moun
    What made it bad is I've already got a bad back. Little cars not a problem I could throw those all day. Fat Ford with 37-inch tires I typically past the job up to the Shop Pup's so I didn't trash my b
    Be careful custom sizes might increase prices fast. Another reason I hung to the 235's they are really common out here and really CHEAP compared to 17's yet. Like my set I'm running now of the Hankook
Just consider this. I'm at nearly 333k miles on the clock and still haven't worn out the stock set of tie rods yet. Why upgrade if the stock steering works this good this long. The only time this does not apply is when you put larger tires on the truck now nothing holds true.
Does your truck wander? I have 285/75/16s what do you have? My steering wanders and pulls all over and I get tired of putting so much constant pressure on the wheel trying to keep it straight. I didn't think 285s were that big considering stock size of 265s. ANother advantage of the upgrade is you get a solid 1.5 inch tie rod which will help eliminate wander.
Mike not to be a smart a** but not all of us like the look of small tires and a low to ground truck haha. I'm not a fan of big lift kits but a 1 inch level kit and some 285s are my style. being that these trucks are known for there steering I'm curious how you got your front end to last so long? You must have small tires and stock height?
No, absolutely not. Straight as an arrow and steering is still tight just like the day I bought the truck from the dealer Oct. 26, 2002.
Ditched the stock 265's and lifted a whole 1mm with 235's. Yeah, 235's are 1mm taller than the 265's so they are 1 rev per mile different. They are only 1.1 inches narrower. Big bonus they are approximately 25 pounds per tire lighter way better on MPG's and less drag for the steering. Not to mention this is the stock one-ton size used. There is actually one size smaller the 225's used also on the one-ton trucks too.
Your not the only one to say it... Don't worry about it. The truth is the bigger the tires the more wear and steering issues you will have. I'm proven without a doubt 235's will not create any wear or steering issues. I've only replaced 1 set of ball joints and 2 track bars now. Factory OEM tie rods, steering box and PS pump yet. Just can't kill it.
Stock height and only 1mm of tire lift. If I want the truck leveled I just hitch up the trailer it sits dead leveled.
You have a very good point!
Thanks.
This knowledge came from the fact I lifted and put big tires on my old 1972 Dodge Powerwagon and end up destroying the front axle. I broke u-joints and tore up wheel bearing and busted 2 steering boxes. For what? Just to look cool. I end up running out of sources for parts to keep fixing the front axle and steering so I traded that train wreck for my 2002 Dodge and KNEW I would never make that mistake again. I didn't as you can see at nearly 333k miles and still got mostly OEM parts yet.
Thanks.
Ok so I was thinking that the large number in tire size was the height! 265s would be narrower right?
265 / 75 R16
10.4331 Inches / 75% of 10.4331 = 7.82 inches R16
10.4" / 7.82" R16 (american measurement)
235 / 85 R16
9.25 / 85% of 9.25 = 7.86 inches R16
9.25" / 7.86" R16
So now you can see the first number is mm in width of tread face. The second number is the percent of the tread face in sidewall height. So now I broke it down to show metric tire sizes into American inches. Still in all the 265's weigh in at about 85 to 90 pounds where the 235's weigh in at 62 to 65 pounds. Way less rotational mass. Faster acceleration with lighter tires and wheels. More fun to beating fat tire Fords with my pizza cutters on Cummins.
1mm is equal to 0.039 inches. As you can see the 235's are 1mm taller.
265 / 75 R16
235 / 85 R16
9.25" / 7.86" R16
I like the fat tire ford part! Lol what is the weight of a 285? I’m thinking about going down to 265/75/16 on my next set which is gonna be soon.
Depends on the wheels. Most people I've seen about 100 pounds per wheel depends on the wheels. Just go to a tire shop and pick up a racing slick and tell me how much is weighs? Racing slices even for wide rear tires are typically 20-30 pound max! It about cutting rotational mass and adding as much traction. Tire weight does matter.
http://hpwizard.com/rotational-inertia.html
Very very interesting. If you got 265s would you do 75 or 80/r16?
Be careful custom sizes might increase prices fast. Another reason I hung to the 235's they are really common out here and really CHEAP compared to 17's yet. Like my set I'm running now of the Hankook ATm 235/85 R16 only cost me $580 bucks for all 4 tires. Like I said Economy, performance is excellent, I've got close 30k on these tires now and still going. Drag is very minimal. MPG I'm touching 21 MPG again.
Another reason for the smaller tire... Walk out in the snow. You sink with every step. Now put on snow shoes and you can walk on top of the snow. So if you want good snow/ice traction you got to go narrower. Wide tires will float on top of the snow and ice and have less traction. Again I can out drive most fat tire Fords on the highway because of loss of traction on ice.
3 minutes ago, Mopar1973Man said:
Be careful custom sizes might increase prices fast. Another reason I hung to the 235's they are really common out here and really CHEAP compared to 17's yet. Like my set I'm running now of the Hankook ATm 235/85 R16 only cost me $580 bucks. Like I said Economy, performance is excellent, I've got 30k on these tires now and still going. Drag is very minimal. MPG I'm touching 21 MPG again.
I guess I’m not aware that 265/80/16 is a custom size? My dad has gotten 80k out of BFg rugged trails 4 sets in a row on his old 06 that he sold. He now has a 2017 Laramie one ton and the factory slicks are already wearing down fast.
Not common size. Like the shops I deal with will charge more because it special order tire and you eat the shipping on them.
Hen I’ll just get 75s I may even jump down to a 255 is that a custom size? Do you have a pic of the front end of your truck so I can see the tires?
I’m def gonna jump down to a 265.
Still though I want to try this steering upgrade! I hope not will take out the wander in my steering and with smaller tires maybe she will really turn good
I'll post new pictures of the new wheels and tires in the daylight still dark here...
Sounds good! Just getting light here.
Want to sell those old wheels?
A lot of us have done this steering conversion.  Yes you have to trim the tie rod stud to fit 16"s
Are you happy with it?
