Starter contact write up
- Replies 10
- Views 10.3k
guesswho512 2 posts
Mopar1973Man 1 post
LiveOak 1 post
eddielee 1 post
it is interesting to note that the FSM says to replace the whole starter, instead of servicing the wear parts. it worked with no problem...then one day....*click*click* i wondered if you could push start a diesel, but realized that i couldn't get that truck up to speed to even try:lmao:
i will mention that while i was waiting for $ and shipping to my door, i took the contact that was the most wore, and made the hole for the stud longer to allow the contact to be closer to the plunger. worked no problems until i got the contacts(6 months later, i know im a procrastinator)
(1) Disconnect and isolate negative cables of both
batteries.
(2) Raise and support vehicle.
(3) Pull back protective rubber boot from solenoid
battery terminal far enough to access and remove
nut securing battery positive cable wire harness connector
eyelet to solenoid battery terminal stud (Fig.
10).
(4) Remove nut securing battery positive cable
wire harness solenoid connector eyelet to solenoid
terminal stud.(17mm)
(5) Remove battery positive cable wire harness
connector eyelets from solenoid terminal studs.
(6) While supporting starter motor, remove three
bolts securing starter motor to flywheel housing(8 or 10mm 12 point bolts, use box wrench or suitable socket)
(7) Remove starter motor from engine (certain diesel
engines have an aluminum spacer mounted
between the starter and the starter mounting flange.
Note position and orientation of spacer before removal).
now you can take the nut on the other side off(15mm). then a phillips screwdriver removes the 3 cap screws. when the cap comes off the plunger springs out. there is a little ball behind the spring(mine didn't come out, but remember it is there, don't lose it). with the plunger out of the way, you can take the out side nuts off the studs. because of the plastic guards, i could not get a good enough bit with a wrench. and impact wrench made short work. with the nuts off, you can remove the studs. the contacts are press on the studs. swap the old contacts for the new ones. try to keep the contact touching the backplate while tightening the nut(they try to twist when you tighten). take the spring off the old plunger and place on new one. put the ball in if it came out. insert new plunger. replace cap. connect the to the stud and install starter on truck!
