White smoke on start up less with warm motor
I have a 2002 2500 5.9 that when started on a cold morning blows white smoke for a min then stops. When I stop some Where and get back in and start up it puffs white for a second. No loss of power no CLE no soft codes. Not sure of fuel pressure. I know I need a gauge. My question is is this somwthin I need to worry about or no? I just started seeing it the last few days. But the temp has been colder the last few days.  Thanks for any and all help!
  • Replies 44
  • Views 6.9k
  • Unreal Summit
    Unreal Summit
    That's a good idea with the fuel pressure gauge. I need to just bite the bullet on it.
  • I don't know what additive you used but I would highly recommend using some 2 cycle oil. I use super tech from wall world. It is good for the entire fuel sytem especially the VP. Today's diesel is not
  • Here is an article about it. One oz per gallon is the desired mix but dont worry if you put to much or dont have enough at a fill up. Any is better than none. Just try and keep it close. TCW3 is
3 hours ago, Unreal Summit said:
Sweet thanks! Hopefully I can return the favor one day!
https://www.dieselautopower.com/diesel-auto-power-75hp-performance-injectors-7x0-0085-vco-vp7x85vco/
What about these? Is 75hp to much for Stock everything else? Sorry for all the questions guys.
Those are good too. I'm running the DAP +75HP (7x0.0085 VCO) injectors.
Without a tuner they might be a bit too smokey. Basically about the same amount of power as a Edge EZ or Smarty would provide +10-15 HP over.
