Can anyone recommend rear lift springs..
- Replies 36
- Views 7.4k
RipnRam99 13 posts
dripley 11 posts
Dieselfuture 3 posts
Silverdodge 3 posts
Mine sits on 2 equal blocks under the bottom spring on each side. I never considered that one to be an overload. I always considered the upper spring the overload spring.
It looks to me like there is a 2" lift block on top of the OEM block. That makes me think you have a 4" lift up front and a 2" lift out back. The lower, bigger, block appears OEM. I agree it's a good
Install a 4 link set up .......... .
The truck I bought has a 6" lift. I think the front is ok, but the rear has huge blocks instead of springs.
I don't like it. Any recommendations? Links to the right springs would be appreciated.
Thanks!
