Engine ECM
Has anyone found a replacement for the bolt in the centre of the plug for the engine ECM that is bolted on the tappet cover.  I found that someone had broken the one on mine sometime in the past.
I Can't find a listing for just the bolt anywhere.  I went to the Dodge dealer and they Don't have any listing for the ECM or Plug let alone the bolt.
  • Replies 5
  • Views 1.8k
  • I did not make it there this past weekend. I am headed there this coming weekend to finish my head gasket job.
Mike I think he's looking for the bolt that holds the electrical plug into the ECM.  I thought I heard somewhere that it was around an M6 x 1.00
Edited by trreed
On 05/04/2018 at 11:00 AM, jlbayes said:
IF I remember this weekend I'll check mine and get info for it.
It would be appreciated.  I'm not sure if I actually need it as mine had been missing for an unknown period of time.  The bolt has a circlip on it so you Can't screw it too far into the ecm
Edited by jlbayes
