- Replies 11
- Views 2.6k
Mopar1973Man 4 posts
dorkweed 3 posts
LiveOak 3 posts
ISX 1 post
Well... Tales from my day... I went into town to get fuel for the Cummins and on my way back home I desided to stop at the local rest area for a pits stop. Well I got out of the truck and notice a older indian gentleman sitting at a table making fishing nets and said "Hello". Then went on about my business... Then walked back out and he asked " Are you local?" I replied "Yeah..." in a kind of confused tohught... He ask what I did for work... I told him that I'm a diesel tech and computer tech... His eyes got bright! He's replies "I got a job for you..." The job... 1996 Chevy S10 pickup - Overheating and coolant leak. I ran home got my tools and headed back... Before I left thoe house I called the local Chevron station to see if they had a t-stat... They had 1 in stock! Well talk to the gent about the issue and the t-stat and I could get one... Well now back to Riggins, ID to get a t-stat... Now I return and pop the old on out without much problems. The old t-stat was rusty and gummy like the valve would hang up as you pressed against it. Then as I was digging around the engine I found the heater hose right at the block had got small pin holes in it and bleed just a bit of coolant to make it smell bad but dry up with the engine heat... (Good find there!
) Just as I finished the gent's nephew shows up in a F-150 Ford pickup. He start explaining about me fixing his truck. Well now the Nephew ask me about a lack of power on the initial take off... I told him it sounds like a vacuum leak. Well I popped the hood and pull the air filter housing right off the bat I found 2 vacuum lines that broke from some where... Then found another rubber hose that split open... So using fishing lead we plugged the broken lines for now. So he fires it up and you can here a good hissing leak yet... I asked the nephew if he had starting fluid or carb cleaner... Lucky! He had some behind the seat. I sprayed the manifold and guess what... It Revved up... Blown intake gasket... Since I don't have the means at that time to pull it apart I knew it would still take him anywhere its just got to be nice to it... So I got paid some cash and a big ol' Salmon fresh today!
