Replaced steering box and pump now it’s not workin.
- Replies 6
- Views 2.7k
Mopar1973Man 2 posts
BigBlock0322 2 posts
Ed ke6bnl 1 post
CTcummins24V 1 post
Hello, I replaced my steering box and pump last night (Both bought through NAPA reman since I’m broke and get a discount through work) and hooked everything up as it was before. I then had the front tires off the ground and turned the tires back and forth about 20 times. Then started the truck and did the same thing. Everything felt smooth so I put the truck on the ground and turned the steering wheel and everything seemed fine. I went to back out the driveway and as soon as I hit my brakes I lost everything. So I muscled the truck around the block and back into the driveway. (Its 2am by this point) So this morning I jacked up the truck and proceeded to do the same thing turning the wheels blah blah. And I still have nothing. Brakes are very hard to press. Is it possible that the hydro boost gave out as well? I’m lost and can’t get this figured out. It is my only ride so I kinda need it working again before Monday morning. So any help would be very appreciated! Thank y’all so much ahead of time!!
