- Replies 7
- Views 4.2k
mopar440cu 2 posts
snowshoveler 1 post
ROWlegend 1 post
jerricuda 1 post
If this vibration is NOT "harmonic" and you're certain its tire/wheel speed related then what you can do is set the truck up on rear jack stands. With someone in the cab at all times for e
@KATOOM has the best suggestion. I would set it up in a driveway or quiet parking lots so if for some reason it jumps the jack stands no one will get hurt nor damage occur to the truck or buildings. H
1998.5 Dodge 3500 4.10 axle dually 19.5 Eagle alloy wheels with new custom steel inner rims, bead balanced tires. new drivelines trans. mount, rebuilt NV4500, DNE od. 3" leveling front 2" blocks rear. vibration in rear noticeable around 55 mph - 70 mph. enough to shake the mirrors, bed welds cracking at rear, and jingle anything in door pockets. I have visited several forums with same issue but never heard of a resolve for this. This is NOT FRONT END, TIRE, OR DRIVE LINE ISSUE. Seems like every time I read about someone having this exact same problem there are dozens of helpful people pointing at everything but the actual problem. I can take my hands off the wheel at 100 and it tracks true, I just cant drive at 100 all the time. It feels like oscillation or out of balance in rear tires, but that's not the problem. I have changed the tires, wheels balanced and re-balanced and nothing changes. I am thinking something in the rear end but cant pinpoint it. No leaks, good brakes, Bosch drums proper oil and LS additive. There must be someone that has actually figured out what this problem is. I have searched many forums about people with the same issue only to watch it turn into a hijacked discussion about what to do about a death wobble. Any actual experience with this would be helpful.
