7 way trailer harness
- Replies 9
- Views 2.1k
Unreal Summit 4 posts
IBMobile 3 posts
Dieselfuture 1 post
015point9 1 post
Sounds like the ground wire became a fusible link and that it was connected to the constant hot which is protected by a 40 amp fuse. The ground wire might have been smaller than 10 gauge and burned
A few months ago I hooked up to a trailer and smoked a few wires and the brakes dont work anymore on it. I been trying to figure out what was wrong with my truck. However using a test like everything is hooked up as it should be. Anyone have any suggestions??
