- Replies 8
- Views 7.1k
Mopar1973Man 3 posts
98whitelightnin 1 post
Dieselfuture 1 post
BIG-BLACK-DODGE 1 post
Slow cranking with good batteries could be, weak starter may need contact plunger kit, or brushes could be loose battery cables and dirty grounds. As for applying some throttle on start up, it does he
Starter most likely. I've seen where one brush fails and the starter is now on half power and struggles to twist. Contacts typically just don't deliver power yeah it does happen that it could cause po
You should not have to give the truck any extra throttle to start! The only time i need to give any extra throttlw is when the ? drops below 0*F and I forget to plug the truck in! If your idle RPM is
Jumped in the rig (1996 2500, A/T, 2wd) and the truck had a really lazy slow crank like the batteries were dead. Batteries tested "good", new fuel filter, new lift pump. Truck just slowly cranks unless you push the throttle a fraction of an inch. Puff of black smoke and presto, she's running. Idles smoothly, runs solid in town and on highway. Anyone else have the same issue? I've read that these p-pumps were designed to be started at open throttle, but I never used to have to do this. Truck is stock, no mods. Thanks for the time.
