New SO vp44 in HO truck, doesn’t feel the same
A little back story-
i bought  The truck with a bad lift pump I changed the lift pump to a raptor 150.  When I went and had everything bolted up in the original location for the raptor and plugged it in and went to prime my truck I realize that the driver for the lift pump through the ECM was bad I was getting no power to my lift pump so I hardwired it to an ignition source .  I knew in the back of my mind the VP was going to be close behind I anticipated the job. About 2 Months ago when the weather started getting warmer once my truck was hot it was having trouble starting it would take a few seconds to crank and then finally start so I ordered a new pump and put it in over the weekend drove it around feels a lot smoother but I feel like I’m down on power and then after driving a while shut the truck off and I’m still having the hard start issue. My FP is 21-22 at idle I’m going to turn it down to 18 or so and the. Wire in a switch for the LP so I can manually turn it on so it doesn’t get to much pressure when starting. That should get rid of the hard start issue.
so the problem is I have a HO truck and now have a SO VP with 120hp injectors and a quadzilla adrenaline and I feel like I’m down a bit on power. The truck runs smooth but not as fast and I get hardly any black smoke now even in my high tune levels. I installed the BD stealth plate and have 12v for the wire tap. Before anything over level 3 (out of 10) my clutch would also slip (soon to be done) and now level 10 in 6th gear I can bury my foot and barely get any smoke and my my clutch doesn’t slip. So I know it’s down on power. I pretty positive my key way is aligned correctly it slid right in and I watched it from the back side the best I could. So I’m stumped
also is the gear for the vp supposed to be able to flop around inside the case? When I went to wipe oil off of it when the pump was out the gear moves around very easily.
Thanks in advance
  • Replies 22
  • Views 7.9k
  • It's not possible.  @TFaoro tried once.  Couldn't get it to jump a tooth
  • If it could jump a tooth we would have been discussing the problem along time ago with as many pumps that have been swapped out over the years.   And I have to ask. If the gear jumped one to
  • I believe the key is important for the internal ckp sensor in the VP and how it is calibrated with the PSG Haven't counted.  Regurgitated information from people who know way more about this th
On 6/25/2018 at 8:54 AM, Mopar1973Man said:
I had really good luck with that and 6x13's in the little truck. From what I have read it was a crap shoot on getting it to be civil.
I ran stock lines and .120 crossover tubes.
That pump is something I would absolutely not recommend for daily driving though.
Edited by Ben
