Fuel economy on iQuad
Can someone educate me on the fuel economy monitoring capabilities of the Quadzilla? I think that the gallon/trip is pretty self explanatory, but I don’t understand what the eco gauge is telling me. My truck did not have a mpg display originally, so I have always hand calculated just for curiosity. I have never recorded or tracked mileage other than a quick check at the filling station. I am curious about these features, as I am going to start playing with tunes and see how effecient I can make this monster.
How accurate is the gallon/trip function? Can I rely on that data? It seems like it would be much more reliable and precise than the “pump until it clicks” meathod.
What exactly is the eco gauge monitoring, and what does it tell us about fuel economy?
any advice on parameters to start with on building my own economy tune?
  • Replies 100
  • Views 26.2k
  • Quadzilla Power
    Quadzilla Power
    I Just finished making a newer version of the average MPG file. I tested it only for around 30minutes so I don't have a lot of drive time on it right now. The only change is the addition of a new sett
  • Quadzilla Power
    Quadzilla Power
    And remember that the ECO and the gallons per trip is only accurate when staying on power level 3 or below. If you are using the pump tap, its more of a rough guideline.
  • Quadzilla Power
    Quadzilla Power
    That's the issue right there. A low pass filter is honestly the same thing as an averager. The thing is that all fuel consumption at any given time has the same weight. For example, while @Mopar1973Ma
That's the issue right there. A low pass filter is honestly the same thing as an averager. The thing is that all fuel consumption at any given time has the same weight. For example, while @Mopar1973Man is sitting in his truck idling he is using very little fuel, but he is effectively getting 0 MPG, when he is driving down the road cruising at 27mpg, he is using more fuel but it carries the same weight as a little fuel. So if you were to take some snap shots of the fuel consumption, you would see something like this (although much more frequently and with real numbers, not stuff I'm just making up for an example)
MPG - Fuel Used - Running Average -  Miles Travelled
0    -   0.1    -    0    -    0
0    -   0.1    -    0    -    0
0    -   0.1    -    0    -    0
0    -   0.1    -    0    -    0
0    -   0.1    -    0    -    0
28  -   4.5    -    4.67 -  112
In this scenario, the actual MPG would be closer to 24.888 but because each sample has the same exact weight the total MPG is skewed way low (4.67). The same issue is happening when you're coasting using very little fuel but the sample carries the same weight as a sample using a lot of fuel.
Well, I think I'm coming closer to figuring out how to fix the issue.
OK, I think I got it fixed. I had to redesign the whole thing from the ground up (just the average MPG stuff), but it should be better. I tried testing it on our truck here but the speed sensor shows roughly 1/2 of reality so it was very low. Try it out and see if this is better.
http://quadzillatech.com/TunesDownloads/V2Tunes/ADR9802v2.8.4.exe
I will flash the box this evening and give it a try
Initial test looks promising! I won’t be filling up again to check the gallon trip for awhile, but the mpg when I parked at work was consistent with my hand checked mpg from the last tank.
iquad-2018-08-03-05.09.43.csv
@Quadzilla Power is there any way to change the tire size to zero for pass through. Still even on my truck my speedometer is dead on, OBDII speed is dead on but Quadzilla is -1 MPH always. You might check but 245s and 215 tire are smaller than your minimum.
95.4" 215/85 R16
95.7" 245/75 R16
Just be aware... The one-ton trucks ran 215's for few years.
One issue I am having with the new update, is the gallon trip and the average reset every time I start the truck. I am not sure if it something in the settings, or if it is the programming. On a fishing trip this weekend, the box forgot my previous level setting and was set to 0 after warm up. I have left it on three, so that was curious. It does look like this MPG average is much closer, but it is just based on trips, not a running average of the tank. Unfortunately, it doesn't look like i will get much good information from this tank since the gallon trip keeps resetting to 0.
check your power connections.  sounds like the box is not getting power when ign is off.
18 minutes ago, Quadzilla Power said:
Hey Mike,
Set the tire size to 95.7 for pass-through of the speedo.
Already done that but still incorrect value between the GPS and the dash gauge the Quadzilla is always -1 MPH off. Dash will show 65 MPH with the GPS at 65 MPH but the Quadzilla shows 64 MPH.
using 95.7 will do math of 1/1 * mph from ecm.
you are seeing a pcm report on chris's tool.  There is also a level of rounding in place when everything is pushed through .
On 8/6/2018 at 11:09 AM, Quadzilla Power said:
Yep, what Me78569 said. Check the power connections, it sounds like its losing power when the ignition is off.
I have looked at my connections, and cant find anything loose. It has been remembering my last power level, but not storing the mileage information. I have been leaving the level on different settings when i shut down to check that it remembers.
The mpg seems to be pretty good, but since it has been resetting, i cant get a long term average or check the gallon trip. I will look all the connections over again tonight. I have my power wire connected to the hot leg of the fuse block under the hood, rather than the battery. any reason that could be an issue?
That is different isn't it. Not losing power level says that you should have a good power and ground connection (hot part of the fuse block is fine in that case).
However, it is weird that you are getting your MPG stuff reset all the time. What is the status of your MPG Offset and AVG MPG reset settings in the settings? Are they both set to ON or OFF?
sorry for the delayed response, work has been crazy! offset and AVG reset are both turned on. I just re-flashed the box a few minutes ago, so i will report any changes. it did take several tries before the flash software recognized the box was connected, so hopefully that is not a problem.
Data logs have been pretty much useless, so i have not been saving them.
Your flashing issue is normal.  All depends on timing.
I would only set these to "on" when you are trying to reset them. You basically want to toggle them on then off to reset the gallons used per trip and the AVG_MPG. I'm concerned that with them on when you connect the app it will resend the signal to reset them every time it connects.
Also, having to try a few times disconnecting and reconnecting the Adrenaline before it flashes is perfectly normal. We have to do that all the time here too.
