Turn Cruise on; the ABS and Brake warnings come on.
Hi,
Correct one problem, along comes the next.  Guess that's why these trucks are called a Labor of Love.
I tried to use the Cruise Control.  All it does is illuminate the ABS and Brake warning lights.
I know I'm not the first.
Leaky
  • Replies 22
  • Views 5.5k
  • Let it grow then sell it as organic sheep feed.
  • Pennzoil 707L Red Grease was my go to for wheel bearing grease and general lubricating but now unavailable almost anywhere.   I'm now using the Sta-Plex™ Extreme Pressure Premium Red Grease which is s
    I use the red grease that you typically find in WalMart. Been good this far...
I see, it's two wheel drive, so are the bearings serviceable then? If they are try to repacking with fresh grease and make sure they're adjusted the right way. And if they're not the maybe they're just loser with time and there is enough slop between tone ring and ABS sensor and that's what's triggering the light. I'm starting to think that might be my problem too.
I serviced the bearings when I installed the new sensors and there is no excess play.
So far, the ABS and Brake light only come on when CRUISE is used.  I took it into town today (32 miles RT) without CRUISE and no ABS or Brake lights came on.
Always something to work on.  :)
Thanks.
Leaky
