- Replies 25
- Views 6.5k
Mopar1973Man 9 posts
Dieselfuture 6 posts
Dmaney 6 posts
KATOOM 3 posts
I have Fastcoolers on my 4500 and overfilled with about 7 quarts of OEM SyntorqLT. My empty driving temps will generally run in the 120-170* range depending on the ambient temperature and how fast I'
Well I thought I'd share my findings on trans temps delivering hay lately. Been hauling the same size load on same road, made four trips over the last month or so for this example. Most of my other deliveries are closer to home and trans never gets warmed all the way up. Trailer is weighing in roughly at 15,000 and making a 70 mile each way trip at 55-60 mph. Takes a little over half way through the trip to reach its towing temp of about 190°. Running empty I usually see 150-160°. Temp probe is in drivers side pto cover, I installed it when I changed trans fluid to amsoil in the spring. I did however take the expressway home today because I was running short on time and had to get to work and was surprised to actually see temps around 200-210° with just empty trailer running 70mph. Just sharing some of my experiences and wondering what some others might be seeing. I would like to try a fast cooler in the future and see if there's any temp drop but for this summer probably will stay stock.
Sorry the pic isn't the best but you get the idea.
