Quadzilla Adrenaline 2nd Gen V2
- Replies 17
- Views 6.3k
Blake2126 8 posts
Me78569 5 posts
hdpwipmonkey 3 posts
rogerash0 2 posts
Popular Days
Reading 0 on build date means you dont have v2
You can specify what tune you want loaded on shipping. Could have been a mix up there. I would call them and talk to them. They will make it right.
Just normal v2. Then you load your custom tune on top. Also 100 hp injectors and a 66 will be a terrible setup.
View FileADRv2.8.4 - Based on the Hard Fuel tune.
Adds the Average Miles per Gallon feature (if enabled in vehicle profile). Requires a corrected speedo and a corrected MPG offset in order to be remotely accurate. Also, you need to run on CAN bus only power settings. Using the wiretap puts this out of the realm of somewhat accurate into the realm of hand wavy accurate.
