Custom pv1 tuning
100hp dap injectors @30 psi boost on stock head bolts
kinda wondering what’s a “safe” point for as max timing and fuel
  • Replies 25
  • Views 4.4k
  • old quad said 8* was pushing it on those old tunes.   fueling it is hard to mess anything up.       I would update to new tuning and the iquad.
Been thinking of going with droid cause I believe I can make a launcher so when the device is powered up it goes straight to the app
20 hours ago, Me78569 said:
if you spend money on a dedicated screen you are stuck with the hardware, as time goes on that hardware becomes outdated and your are forced into a cycle of updating hardware as new stuff comes out.
Agreed. Hence why Edge Juice has to change constantly.
1 hour ago, Me78569 said:
I swear once I got it to connect 1x then I could just leave the app running and it would connect without fail within 1 minutes or key on, %70 of the time within 30 seconds.
Not true either. Someday I just leave my phone out in the truck in the cradle. Most of the time it hooks back up. Sometimes it just tries once to connect and quits regardless if the app is left open in the truck. Strange is I can leave the app running on my phone and carry the phone around come back to the truck and still have connection issues. There is day when I need to monitor for phone calls. No, I don't want two cradles in my truck one for iQuad and one for my cellphone.
1 hour ago, jigabop said:
Thanks
  • 4 weeks later...
Thats why i been thinking of using a dedicated droid device S4 Active and trying to make a pillar pod for it, IDK might be more trouble than its worth
