ENGINE MISS AND LOPING IDLE
- Replies 6
- Views 5.2k
Mopar1973Man 2 posts
madsen 2 posts
Dieselfuture 1 post
Dmaney 1 post
I have 2 issues with my truck. Some times my idle lopes from 800 to 900 rpm. This issue seems like not a big deal but maybe points to the other issue of a miss at idle and at speed.The lope issue seems to be only while the truck is getting up to temperature and it is inconsistent. The second issue is the truck develops a miss as it warms. I have isolated it to cyc 3 and 4 by using a snap on code reader /scanner. My son thinks I have a couple of leaking injectors or possibly crossover tubes. Truck gets good mileage 14 in town and over 20 on the road at 70.Truck information ; 180 k miles 3/4 ton 4x4 5 speed. Fairly new injection pump 20 pounds pressure at idle.Some black smoke at start up.
Question is any way to diagnose further without removing injectors and if its injectors should I repair 2 , clean and repair all 6 .....Thoughts suggestions ideas are welcome.I am not really a mechanic but can read and figure out things slowly. My son is a mechanic with 6 plus years experience and does diesels for a living working on over the road big rigs. He helps me when I get stuck/ over whelmed.
