99 Engine swap - engine year 55 block
I bought the truck in the pic.  It's a 99 dodge ram 2500 5.9 manual 4x4.  It had a 55 block swap and trying to determine the year of engine is in the truck.   Any help is appreciated!
  • Replies 4
  • Views 3.9k
  • Dieselfuture
    Dieselfuture
    If you take engine number off that Cummins plate, then call Cummins they should be able to tell you what it came out of.
  • @SavageTusk You can also do it through Cummins QuickServe.     https://quickserve.cummins.com  Make a free account and add the ESN.
Pretty sure it's an '01.  I'll give cummins a call, thanks!
When my 99 `s block cracked , Cummins removed everything from the 53 block and re installed it in a new 55 block with new piston rings and all seals , the engine id plate is on the timing cover that was re used , its off the original motor .
Only cost me 4300.00 for the labor , parts free , out of 100k Cummins warranty , 12 yeas ago , still hurts
