Tranny lunges in gear/odd shifts 40mph max
I have a 2001 2500 4x4auto. I recently changed the entire body which was rotted to gas truck body. Went fairly well until I started truck and found out that power steering pump shaft broke? And hydroboost went as well. Fixed both and can steer and stop but now tryed to drive it and when u shift out of park it basically jumps into R or D depends on what u select,seems like brakes almost don't want to hold truck back,try to accelerate and truck moves then slows down then shifts then revs then shifts and 40 is highest it will go will Erving high?please help truck drove beautifully before changing bodies. I'm new to site so please excuse the way I described this problem,thank you
  • Replies 34
  • Views 5.2k
Truck is still down,I've traced tranny wire from harness to tranny.all in good shape no cuts or knicks. But when I unplugged main tranny plug the truck stopped wanting to jump into gear?
Question, when you swapped out the bodies did you also swap over your wiring?
I would put your truck into manual 1 and see how it accelerates, I'm thinking your limp mode because it doesn't like the wiring.
Can you expand on this?
Usually pulling the trans plug will force the valve body to run without electronics, so you should have 1-3.
If your live pressure is to high you will start in 2nd gear which will cause a dragging feeling.
Did you try to stay the truck in manual 1 position and see if it drives better, you'd have to shift to manual 2 when you hit ~15mph.
I will try manually shifting today and report back,I believe it didn't shift at all out of first when I unplugged tranny plug
Have you looked at this article?
On 10/9/2018 at 10:10 AM, CDeGolier2001 said:
I checked and I have 14 volts at the wire? Bad alternator?
Which wire are you speaking of?
The alternator can produce between 13.4 and 14.8v DC normally when commanded by the PCM.
But the AC sign wave is what is of concern. Have you attempted to drive there truck with the alternator un hooked?
I have and it didn't change anything,and I guess I was checking the orange black stripe wire
I believe that should be 5v correct @Mopar1973Man
The wire I checked also had tap on it for tq locker. Is this the right wire that should have 5v?
1 hour ago, CDeGolier2001 said:
I have 14v at the orange/tq lock wire is that proper?
Yes. That is normal. That means the power from the Transmission relay is reaching the solenoid and the orange black is open currently. Again the only thing the PCM does is control the time at which the orange/black will ground which will lock up the torque converter. Then if it opens that connection then unlock the torque converter. As you see the alternator field wire (blue) which is the key on sense for the transmission relay to send power to the transmission.
