  • Replies 14
  • Views 2k
just saying hey from va?? How many are runing a 53 block with 500+ hp without any issues
I’m looking to get a bigger turbo and injectors looking somewhere in the neighborhood of 550 rwhp tow some every now and then mainly looking to sled pull and weekend warrior it’s a 5 speed with a street dual disc sb quad v2 and raptor 150 lift pump
I would just ensure you are realistic about your goals.
A fun 500 hp truck is easy, 7 x .010 62 turbo and a quad.
I dont htink that will get you far sled pulling though
Street stock class can’t compete in the big boy class unless u got 1000hp+
I was looking into a 64mm and 200 injectors
This is where towing vs fun comes into play.
the 64  could tow ok if you go with a tighter exhaust housing, but that means the upper end will be more restricted.
Give and take, just be aware of it.
Yea I know the only way to have the best of both worlds are twins but I have a 5 speed with 4.10 gears I don’t think it will b laggy enough to worry about anyone with input from experience with a 64 with 200 sticks on a manual truck
Heaviest thing I tow is my toy hauler which is around 9-10k lbs a couple times a yr
So if I go with a 12 housing I will have more low end and less top and vice versa with a 14
yep,
the vp44 trucks make power in the 1800-2400 rpm range.  Keep that in mind when choosing a turbo.
What do u think of a smedding S363 63/68/14 will that support 550-600 hp and still tow ok
not what I would want.   Twins are really needed after that 525-550 mark
vp44 + 14cm housing = not great
Edited by Me78569
Funny part I've seen guys with RV275 injectors running twin turbos. :duh:
