Subwoofer pop when stereo turns off
- Replies 10
- Views 2.2k
SavageTusk 4 posts
Mopar1973Man 3 posts
2000Ram2500 2 posts
KATOOM 1 post
Popular Days
Just like me shutting down my exhaust brake I get the crack from the discharge of the solenoid magnetic field just like an ignition coil. You'll need a proper filter diode like in quality relay have t
Here's the link. It is a 1 din but has a 4.1" screen. Nice for the backup camera. Operationally, it's OK but there's a lot I'd change for ease of use. https://rover.ebay.com/rover/0/0/0?
I have an issue that you small electronics guys may have a solution for. When I turn off my car stereo, there is a delay for the screen to shut down. Once the stereo turns off there is a loud thud from the subwoofers connected to an amp. I have reduced the remote turn on wire from 12v to 5v via (2) 1k ohm resistors and still does it. My thinking is that there it a voltage spike when the radio turns off causing the problem. What would I use to catch this or how would I "filter" this spike?
