Towing air bag recommendations
- Replies 15
- Views 3.2k
Towrigdually 4 posts
Dieselfuture 3 posts
015point9 3 posts
Bullet 3 posts
I had good luck with the Firestone bags. The quick connect fittings that came with them always leaked where the hose connected. Not a bad leak but would have to put more air in if I let it sit for 1
https://s3.amazonaws.com/cdn.genosgarage.com/downloads/InstallPDF/PacbrakeHP10019.pdf 2) Check the vehicle to see if it is equipped with a 5th Wheel Hitch. Some 5th wheel hitches re
I had the same issue with turnover ball mounting hardware being in the way, so I had to redesign the kit and make my own brackets. So my airbags are not sitting on top of leaf spring, instead they are
Looking to help with the heavy loads but I find online with most kits They say I need 8" between the frame and the inner dual tire.
Does anyone have a kit that perhaps mounts different that'll bolt up or tell me I don't need that much space, currently only have 6" On the truck.
Edited by Towrigdually
