Gen 2 Map sensor Flakey
Hi Guys, I have been learning alot about my cummins from reading these forums. This is my first post, so please forgive me if this topic has been covered.
Background:
I finally got my quad adrenaline board replaced and I had no boost pressure. I replaced the map harness because there were a couple butt splices in the wiring and presumed that was the problem. Once I changed the harness I have a boost reading on my control pod of 48-51 pretty consistently no matter TP, speed, ect. I did some reading on here and found out some map sensors "Fail High", which seems to correspond to my issue and also gives good reason to my poor mileage 8-10 mpg. Occasionally when I start the truck up the boost starts at 0 and will go up to 20 or 21 depending on throttle, ect. But usually goes right back to 48-51 upon restart.
I ordered a map sensor from Advanced Auto for $135 with a 25% online coupon and when I received it the connector was more oval shaped than the one on the truck, so I returned it. I called the dealer today and found out that they sell a Boost Sensor and a wiring harness for $370 something. The parts guy didn't know much so that is why I am here.
Assumptions:
1. I am currently assuming the Map sensor is still bad even though it occationally works.
2. I am assuuming cummins has updated this sensor with a new connector style and requires the new harness to connect.
Questions:
1. Is it normal for a map sensor to sometimes work and sometimes not being either/or on start condition? Or is this an electrical issue?
2. Are my assumptions correct about the new connector type and require a harness?
3. Recommendations for sensor and harness? Or old style sensor connector?
Below is picture of Old sensor on the left and new sensor on the right.
Thanks in advance!
  • Replies 10
  • Views 6k
  • They definitely quit making the 02 style and an adapter harness is needed. I have one on mine but dont remember where I got it. But I do know $370 from the dealer is a rip off.
  • Check this out. Pretty sure this is where I got mine. Just been to long ago to remember. https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,fuel+&a
  • dripley and 04Mach1, You guys are awesome! Thanks.
Background:
Assumptions:
Questions:
Thanks in advance!
By looking at the picture I think Advanced gave you one from another year. If you are near a Cummins dealer or even a truck dealer like Freightliner or Peterbilt that deals with Cummins you will get a better deal than messing around with Dodge dealers selling the exact same parts with a Mopar sticker covering the Cummins sticker.
Just the harness from the dealer was 60 some dolars. I figured maybe buying the harness from the dealer and buying the sensor somewhere else. Unless I can get the harness somewhere else as well.
https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,fuel+&+air,manifold+pressure+(map)+sensor,11207
One comes with the adapter. You can also check with Cummins but I dont think the OE is still available any more.
Edited by dripley
So after a little research I found Cummins updated the MAP sensor for 2002.
You'll need Cummins part numbers:
4921505 - approximate cost $110
3104228 - approximate cost $25
So with genuine Cummins parts your looking at about $135.
The pictures on rock auto don't match the description. P/N: AS370 has pictures of sensor and harness for $87, but Description says sensor only. P/N: AS370K has just picture of sensor, but description says Sensor Kit, Includes Harness for $149. Looks like Geno's Garage has both the cummins parts for $111. Don't misunderstand, I am not necessarily looking for the cheapest initial cost.
Anybody experience the aftermarket sensors outlast the Cummins sensors, disregarding the $30 ebay parts?
Pretty sure they have those backwards from reading the descriptions. I do have one of the SMP in mine and has been for several years. It works just fine. But looking at @04Mach1's post the Cummins is cheaper. That was not the case when I bought mine. It was a lot more back then and thats why I went with the SMP.
