NO BUS message on odometer
I sent my ecm in for repair and WTS seems to work correctly but now on odometer I have a no bus message. Also abs, air bag and mil lights are on. Odometer codes are 900, 920, 921, 940, 950, 999 and gauges don’t work. Codes are p1698 and p0237. What do you use if you don’t have DRB III tool? Would really appreciate any help you folks can offer. Thank you
  • Replies 22
  • Views 5.3k
    Your welcome (under my breath - That suxed...)
  • I'd send it back and have them fix it.  Sounds like you have bad signals on the CCD bus
    Sorry for the lag... Mine was 700 plus shipping. Mine was a full replacement.
24 minutes ago, Dieselfuture said:
If had to happen to you, otherwise this mod would have never came to existence. Someone else would have just replaced PCM and alternator and moved on without figuring out what can be done to prevent it
Actually no. That's not true.
They would have replaced the alternator and found it doesn't charge then grab the other write up and install an external regulator and go on.
Now you can add the newer mod and never worry about the PCM failing.
  • 3 weeks later...
YeeHaa!! It’s running again. ACS said nothing wrong with PCM they just had trouble getting it to connect. They told me not to use dielectric grease.  $150 to test. When I hooked everything back up I had 16 codes. They all cleared except for P0237. I disconnected my edge and cleaned all connections and all is good. Thanks for the help. Sending a donation today.
