SHOCKS
Hey guys I have a question.  My truck has the option to install the front shocks inside the coil springs or on the side of the coil springs.  Which is the preferred method please?
  • Replies 6
  • Views 1.4k
In side the springs is how mine install. I have no way to mount them outside. It did not come from the factory like that. As far as any advantages  to being outside, I would not know.
Yours must be a 2wd. Outside would easier to change in future, and depending on location of pivot point you may get more or less travel.
sounds like an aftermarket coil bucket mount...for dual shocks ( a bad thing, if stiff shocks are chosen)
the factory setup is in coil.
