So I been in a love/hate relationship with my Iquad for a year now. Today I decided to give it one last try. I uninstalled and reinstalled Iquad app on both my Android devices. Downloaded the tunes directly from this site I wanted and added them, and added, and added. The only one I downloaded would not show up in either device. When I went to import the tune for the second and third time's. It popped up the file already exists BUT it would not display under custom tunes!
So I got to looking at vehicle selection. That's where I saw the differences between devices, same version number. Different title. See pictures
There is also additional Quadzilla test V2 selections in the newer device in addition to the 2 selections for V2 Dodge 1998-2002, v2.7
The older Android has only 1 V2 selection for Dodge 1998-2002 v2.7
So, when I switched vehicle selection from V2 Dodge 98-02 v2.7 to the V2 Dodge 1998-2002 v2.7, the import files showed up!! How the heck would anyone know to switch to the 'other same' vehicle selection?? Why is there 2 for the same vehicle and same version number? Why is it so dam hard to stay connected Bluetooth? I never loose connection to my stereo or my earpiece. I would pay for a longer harness to run the Bluetooth module inside the dash vs engine compartment.
  • Replies 59
  • Views 13k
  • Quadzilla Power
    Quadzilla Power
    Truthfully, I don't know why there is a V2 Dodge 98-02 vehicle selection. It may be that you got an update.json in the middle of a transition. Once you download a vehicle profile it will stay there un
  • Yes sir, that's what I'm doing. It will cost me $25 for the service plus shipping. The last amount I will ever spend on that device. Of it was over $50 total,, it would be in the classifieds already.
  • dieselautopower
    dieselautopower
    Thanks for the heads up Nick. I will send a link to the thread to Spencer and Marco.
I honestly don't recognize the Feature Code, but it looks like it programmed successfully. If you can see the feature code, then don't worry about the problem you saw above, that was just the step needed to install drivers so that you could get to the point where you could connect to the Adrenaline. You have connected and successfully updated your module, probably to the version that Nick uploaded here.
I dont remember a LI flash feature code.
@Quadzilla Power  is there an official V2 now days?
Edited by Me78569
It's Nick's Long Idle flash.
This is what happened when I was disconnecting the BT module from the harness to ship back this time. It came apart completely, all four wires. Odd.
So I will be shipping it back tomorrow. Is there am extension for the BT module wiring where I can run it inside the cab for better connection? Since it's fell apart now would be the time to add 4' of wire, lol.
I bet money your issue is right there with all the tune loading stuff...
Think i should try to fix the wires and go at it again? I not sure i have those connectors. Wierd how they all 4 are 'broken' so evenly.
Edited by ROWlegend
I would let quad fix it in house so they can verify and not have guess work involved.
Yep. let us fix it. It was a manufacturing defect that we know about. If you want, I have some longer cables that I can put on it. Its easier for me just to fix this cable rather than having to re-solder on new cables, but I will be willing to help you out and put a longer cable on it.
I appreciate it Quad! Look forward to a bad a** unit coming soon!
Well fellas it appears the connector was the culprit the whole time! It's working good and I can load tunes without issues!! Thanks for the help everyone and Quad for fixing it all!!
  • 1 year later...
loaded the app on an older android device running 4.4.2 and i only have demonstration in vehicle selection nothing else why could this be
4.4.2 might not be ableto download the vehicle list.  Older os's dont meet ssl standards.
but I have other devices running that OS that work ok but they also have been on there a while also app states that it works with 4.0 and up just kind of weird trying to use android  gps unit cause it comes on automatically with power just like a monitor
the app version 1.9.43 works with the android 4.4.2 but the newer 1.9.45 does not from what i am seeing is there a way i can get the older version of the app to put on my device to use
 I still have had no luck with getting vehicle selection on this thing even going to older version . Does it take a special connection to get vehicle selection? Just not sure why it wont work on this but has on others.
