- Replies 27
- Views 5.2k
								98whitelightnin 9 posts
								Marcus2000monster 6 posts
								Mopar1973Man 5 posts
								dripley 4 posts
Popular Days
								Almost too pretty to put on the old dodge
								Do not do quick ratio. Only use quick ratio on stock and smaller tires. Your running 285's. Wrong ratio for larger tires and places too much stress on the box.
								I am with you on the 265s. I can see the advantage towing with the 245s but dont t.wan to increaed the rpm cruising the highway. The Cooper ATPs have done well in the snow. I dont drive in snow a lot
So this 4wd 98 I just picked up is all over the road. Ive replaced all tie rods, both wheel hub assemblies and shocks and springs, it was all shot, except for the R hub assembly. Springs both had rubber spacers between the coils and shocks had no rebound. I had an alignment set at 0.07 total toe. R side cam bolt has a bent washer so i set those straight up and down. Truck pulls left driving down the road and pulls left when braking. Had small travel trailer in tow yesterday and had to hit the brakes hard in traffic and the truck darted over in the left lane. Track bar is tight but the steering box needs replaced. I did tighten the adjustment on top of the box and it took a lot of slop out but still not all. Ball joints are greaseable and in great shape with no binding. I also put in new sway bar bushings since the old ones were shot. Truck rides so much smoother now with new shocks and springs but just doesn't handle like it should. I cant keep replacing parts if they don't need replacing but I know these trucks can drive great. What do we think? Steering box, control arm bushings, steering shaft? Tires are 285/75R16 toyo open country a/t in great shape but i'm gonna rotate just'' to make sure nothing is going on with that front left tire.
Edited by 98whitelightnin
