- Replies 18
- Views 6k
Buggy78 8 posts
Me78569 6 posts
Mopar1973Man 3 posts
903Dodge 1 post
Popular Days
So no bucking on lvl2? Boost defuel and egt defuel. Turn them off for testing. If it does buck onlvl2 then try lvl 3 and repeat. If it pannes on lvl3 it should h
Timing is not even. Like mine above is +3.7 evenly spaced. 16 + 3.7 = 19.7 + 3.7 = 23.4 + 3.7 = 27.1 RPM is linear and timing should follow the same linear scale.
Hello newbie here, I’m having issues with a new Quadzilla Adrenaline v2 iquad it’s got a pretty bad (what I would call) buck at what seems to be around 18% throttle position. When accelerating it’ll hit 17-18% throttle and start jerking no matter what the speed is and seems to be worse on a grade, when easing out of the throttle I get the same results 18-17% throttle a hard starts jerking,I have tried everything I can think of to tune it out and no matter what I change it’s still there. Swapped apps sensor off of a friends truck with no luck same thing. I have put about 350 miles into just trying to tune this out. I’m about at my Witt’s end and considering just putting my edge comp back in but would really like to make this Quadzilla work out because of the extra features it has. Any help would be greatly appreciated.
