- Replies 28
- Views 4.9k
portlandareae28 9 posts
JAG1 6 posts
Shainer 6 posts
Bullet 4 posts
Beside the satisfaction and pride doing it yourself is the avoidance of poor workmanship and overcharges so common today. I have experienced so much of it my whole life that I finally rebelled, buying
Still not that bad. The inside bolts can be reached by removing the kick panel and the use of the proper tooling for the upper. Then unbolt the door from the hinges and secure with assistant/stand (
They are easy to replace. I never did one until about two yrs ago on my first gen Dodge. I wish I had done it sooner than later as It really was easy to do. Main thing is to find something to support
Wondering if anyone has had door hinges replaced and if so on the quad cab did anything need to be done with the rear doors? Interestingly enough I am having issues on the passenger side (which rarely gets used). The sheet metal on the door is getting a little mangled around the latch from hitting the striker post (is that what it’s called?). Also if anyone had a body shop do this, can you give me an idea of cost?
