  • Replies 5
  • Views 3.4k
  • @Quadzilla Power.  Does the base flash have high idle enabled on lvl 0?     @Thebeastxj00. Please consider ditching the pod and getting the iquad.  The power of v2 is pointless If you c
@Thebeastxj00. Please consider ditching the pod and getting the iquad.  The power of v2 is pointless If you can't tune with it.
Edited by Me78569
13 hours ago, Thebeastxj00 said:
How do I turn on the high idle on my quadzilla adrenaline v2 with control pod
Set the warmup mode temperature. Like I've got 170*F for this setting. Then you need to set the high idle delay time which I've got 15-second delay.
Warning don't run the Quadzilla high idle with the factory high idle on the ECM  enabled. If for chance the 3 CYL mode is kicked in while the Quadzilla running 6 CYL it will create a heck of a problem.
he only had the control pod, he does not have the iquad so he can't custom tune or setup custom values for things like high idle.
