- Replies 8
- Views 3.4k
dodgedieselnewbie 3 posts
kzimmer 2 posts
AH64ID 1 post
CTcummins24V 1 post
Hi guys/gals...
Last summer (camping trip) I had an issue with a band anchor coming off and wedging itself in linkage.. this was coming up an incline and tranny made a slamming jolt from first to second. Long story short... local tranny guy reattached band/anchor. Drove home with camper and everything seemed okay. This lasted about a month... then it starting doing this double hit into second (like it didn't grab the first time).. then as tranny got warm I'd completely lose first gear. So.. when I first start out.. drives fine.. as it starts to warms (10-15 mins).. double hit first to second.. then when warm loses first gear. So.. winter came and I just parked it... until today. I decided to check things out.. same issue. Found that the fluid looked to be a quart over full tho... drained some out.. no change. Fluid does look somewhat cloudy or marble looking?
I bought this truck with the tranny already built... to hold 850hp. The transmission did the slamming jolt one time before about 3 years ago.. Anyone have any insight as to what may be going on? What may be the cause of the jolting shifts happen.. I mean.. it hit super hard those two times. First time 3 years ago scared the **** outa me! Also... I can manually shift into first and it works fine... and 2nd to 3rd to overdrive shift fine.
And... anyone know why an anchor would come off? Is this an odd thing to happen?
Thanks...........
EDIT:
Would you just go to a regular local tranny shop in my situation or go somewhere that specializes in builds and diesel truck? The latter is 2 hours away... Anyone know of or can vouch for Muldoon's Diesel in Delaware?
I want to go to someone that knows what they're doing and won't tell me I need a complete rebuild when I might not....
Edited by dodgedieselnewbie
