- Replies 27
- Views 4.8k
Mopar1973Man 8 posts
Coltenkrause 5 posts
Dieselfuture 4 posts
kzimmer 4 posts
Wait to start should display regardless of the CCD Network as long as power is supplied to the ECM the very first instruction is the WTS light for either bulb test or fire up the grid heater. WTS is n
What is that red wire that has a messy connection to the alternator output terminal? If there are more wiring connections on your truck that are done in that manner, I would be thoroughly looking ove
It's OK to temporarily test it like that, not recommended to leave it without reprogramming it to your truck.
I have an 02 24v 6 speed, just did injection pump. Everything is good there. Cracked injectors got fuel to them, closed 3 off truck fired up. Took it for a test drive n everything was great, brought it back to the house, shut it off waited 3 mins and fired it back up nps at all. Shut it off cleaned up tools etc. Went to start it and now it won't start. Lots of fuel to injectors, but keeps saying "no bus" on instrument cluster. My super chips programmer can't even connect to it. Just cranks and cranks but no fire. Any help would be greatly appreciated.
