NAPA EP27L Flasher and Hyper- Flash
Hi,
I'm in the process of changing my light bulbs to LED's.
Following Mike's lead, I installed the EP27L Relay from NAPA to eliminate the notorious Hyper Flash on Turn Signals.
The Hyper Flash is gone, but I noted the Relay clicks 2 or 3 times AFTER the signal is cancelled.  Happens regardless if its Left or Right.
Is this what others are experiencing?   Not a show stopper, just curious.
Thanks.
Leaky
  • Replies 8
  • Views 2.6k
I saw a review (for what those are worth) of this Flasher.  Reviewer claimed he had same issue using it in his Excursion.  When I cancel it, the lights go out but you can hear the relay doing 2 residual clicks. PFM I guess.
i will have to look at mine, i did LED about 4 yrs ago...not a single issue since. i used an LED flasher recommended by cumminsdog from CF.
What brand/type of bulb are you using?
