- Replies 11
- Views 2.2k
Mopar1973Man 4 posts
dripley 4 posts
Haggar 2 posts
Popular Days
Drip, That's it if the valves were open. To the gulag with you!!! (you have not reached "off with your head" level yet.) Both have to be closed. When you want to add some
The only way I add anything to the high side is if I know exactly how much freon I need to add. Say I was rebuilding my A/C system and it was pulled down on vacuum and ready to go. With the engine off
Thanks guys, @Haggar and @Mopar1973Man. Those gauges fuzzle my brain sometimes. But I have managed not add anything to the high pressure side of mine or the wifes car. Matter fact I rebuilt both hers
My AC has been working so far this yearbut is getting a bit warmer. It was hitting about 40* out the center vents but has crept up to about 55*. I put gauges on it and static pressure was about 80 psi. Started the motor and the high pressure is about 140 but the low pressure is pretty much pegged and bouncing.
The compressor clutch is engaged, ambient temp 85* and center vents at 55*.
Low pressre switch? Thought that should shut the compressor down.
Expansion/orifice tube maybe?
