Headlight switch! That old story!
- Replies 6
- Views 2.2k
billhulbert 2 posts
Mopar1973Man 1 post
gipperkid 1 post
wil440 1 post
Popular Days
Here's what I can do to help. At the top of the page is a 'Downloads' tab. In the menu is a download for the 2001 FSM, and 1997 wiring maps and FSM as well. Headlamp switch is in section 8W in the 200
If you need the correct switch let me know.
Wrong switch. It should be the rotary switch 3 position (or 3 position with pull out knob). The pull out switch stopped in 1998 and 1999 went to rotary switch.
OK 2nd gen gurus I have searched for days and now must ask. Working on getting the headlight switch operational again in my 01. PO spliced in a pullout type HL switch which looks to be from the 97 type rams. So what I have is power to the headlights constant. which I believe is correct. So feeding into my HL switch I have a pink and red that is hot constant. The red and green which is the largest going in should also be hot constant but is not. However if I turn on the switch the red/green becomes hot. Also the LG wire that is HL output to the dimmer in the multifunction switch is constant hot. I believe the LG should only become hot after the HL switch is pulled out the the HL illuminate position. So any input would be great and thank you for the help in advance.
