2001 Altenator Charging WOES
- Replies 34
- Views 7.4k
int3man 12 posts
Mopar1973Man 11 posts
JAG1 3 posts
dave110 2 posts
@int3man The W-T mod does not include a circuit breaker on the charge line from the Alternator to the passenger side battery. This additional aspect was introduced in later subsequent contributio
and a Colt 1911 I have the same fuse set up in my 5th wheel between the batteries and a power invertor; 15 years now and no problems. You carry spare fuses for the two fuse boxes so
http://www.fostertruck.com/dodge/dodge-battery-cables.html
Hi Guys,
O.K. WT modification and did the 150 Amp circuit breaker modification 6 months ago followed up with the Fuse in the field wire. Got in the truck and drove to the post office 98 deg. AC on full. Come out of the post office and cell phone charger is flashing Low voltage. Volt meter is to 0. Stop get out and reset the circuit breaker, it had tripped. Get on to freeway and drive to next town for dentist app. Bam the voltage drops to 0. Pull over after getting off the freeway, reset circuit breaker. Turn off the AC, roll the windows down. Start Truck and we get 14 volts. Drive for a bit and the Faulty gauge idiot light comes on, still haven't fixed the oil pressure sending unit. 90 seconds later the volt meter is diving. 12.5 12.3 12.1 Bam 0 Breaker reset. Made it home after the dentist.
So did I blow a diode pack or what. This is a rebuilt Alt that has worked perfect until today.
TIA
Michael
