Looking for Staff Members
Just purchased a qaudzilla iqaud for my 01 Cummins. I'm just wondering if there are some good tunes to download without the pump tappes?  I've got 125hp sac injectors, airdog 100gph, and a 62/68/14 turbo going on with them just not wire tapping right this min.  Thank you!
  • Replies 5
  • Views 1k
All the tunes I'm seeing all need your vp to be wire tapped.
My economy tune doesn't require wire tap. I typically use level 2 or 3 for daily driving to limit fuel tables as needed. 4 and above just added fuel and degrades the MPG numbers.
Use any tune you want that works best, just stay on level 3 and wire tap will not work. Anything above 3 uses wiretap, the more levels you chose the more it splits the power. I use 6 levels to get to max power sooner, but mostly stay on level 3.
