Hydralic Brake Booster , possible leak
- Replies 7
- Views 3.2k
GSP7 3 posts
dripley 2 posts
01cummins4ever 1 post
Royal Squire 1 post
Popular Days
You do not need to remove the blue canister, I also used the pirate jacks kit, I think that’s what is was called, it’s been awhile. but pretty straight forward on the rebuild. You can just unbolt the
I replaced my hydro boost this afternoon..... was going to do it Sat morning , Getting tools ready and looking what needs doin' .... Looks easy so I went for it in 99 degree afternoon weather... Took
I noticed a oily little leak on my frame looking in the driver side wheel well. Examining under the hood and with a mirror I see oil moister on the Hydralic brake booster. Power steering fluid isnt down to bad, check hot, might be slightly down but not at the add line at all
I thought at first it might be the master cylinder but its dry right where it mounts to the hydraulic booster. Looks like there is a little leak drain out hole on the middle bottom of the Hydraulic booster kind of like a water pump has
I used a little de-greaser spray and hosed everything off clean so I can see exactly where its leaking from next time I drive
Any one have their Hydraulic brake booster leak and had to replace it?
