Help with a Towing Tune
- Replies 18
- Views 7.3k
KRob 8 posts
Mopar1973Man 7 posts
Me78569 3 posts
I am running a 2001 Dodge 6 Speed with 75HP injectors. It weighs in at about 8500lbs (flatbed, tools, and my fat rear end). Last week i towed a 2000lb trailer with another 8000 worth of stuff and the EGTs were pegged going up hills, even driving like i have an egg under my foot and gearing my way down through the gears. I also on a couple of long pulls was outside of the normal operating temp range and finished one hill in 2nd to keep it from going way to high.
Today, i am just pulling the trailer 8500 (truck)+2000= 10500 ish and my EGT are once again at 1200 and i ease out of the throttle. So I am curious what tune wise can I improve on. I run from sea level to about 5000ft. (I am not real sure i have the timing portion set right.)
power level 12 (running on 4)
RPM 3400
Max Val 50
max fuel stretch 1600
TPS Max100
TPS Min 30
Min pup 8 psi
Boost Scale 34 psi
Max Load Timing 3
Low PSI Timing Reduct 5
Timing reduct scale 50%
Light Throttle Timing Adv 1
Light Throttle Load Limit 30
RPM Timing Max
1500 . 16
2000. 19
2500. 22
3000. 25
Max. 26
Boost Level
0-5PSI = 100
6 through 10 PSI up by two. 102 - 110
11PSI through 18PSI up by 4 . 114-140
20PSI on is 150
Any thoughts would be really appreciated.
