NV 4500 Overdrive Noise
- Replies 10
- Views 3.9k
Rotax3006 5 posts
Mopar1973Man 3 posts
Dieselfuture 2 posts
Popular Days
Nope. Still working perfect.
Yup. Just got done with the exact same problem. My last rebuild the lower gear was replaced but this gear wasn't. Fatigue took its toll and sheared off the whole patch of teeth. Now both gears are rep
Hello Everyone
So my truck has developed a new issue this past weekend. Heading home from the mountains I was cruising at about 75 in 5th gear. Pulled out to a pass a truck and began to accelerate. Let off for a second and the transmission began to make a clunking/knocking ticking sound. Kind of sounds like the teeth are slipping past each other or not meshing correctly. Only happens in 5th all other gears seem fine. I'm thinking I either lost some teeth on a gear or the shift fork/pins brake and its not engaging the gear all the way. Anybody experience anything similar? Finally do I have to pull the transmission to change out the overdrive gears if that is the problem? The transmission was rebuilt by a reputable shop about 70000 miles ago so I don't think its in too bad of shape other than said issue. Truck is a 98- 24v, 4x4.
Thanks
Bill
