2002 Cummins. Scanner wont communicate with ECM
- Replies 10
- Views 12.3k
Goosed59 3 posts
Mopar1973Man 2 posts
wil440 2 posts
IBMobile 1 post
Have a late 02 ran 2500. Cummins automatic 4x4. Truck has a issue believed to be failed MAP sensor. Tried two different scan tools and neither connect to the Engine.
I can communicate with PCM and watch data on the scanner. It wont let me communicate and watch data on the Engine side. I can check engine DTCs but once I hit DATA DISPLAY it says no communication.
Have checked and all fuses, and wiring appears to be perfect based on a quick visual inspection. Have not pulled out the DMM yet to check. Engine starts, truck runs. OBDII has power. Anyone ran into this issue before?
