Engine Coolant Temperature Mismatch
- Replies 13
- Views 5k
fendercare 5 posts
Mopar1973Man 4 posts
AH64ID 3 posts
IBMobile 1 post
I have searched until I am blue in the face to no avail. I have a 2001 24 valve with a Quadzilla Adrenaline tuner installed. At engine operating temperature the coolant temperature sensor (located right next to the thermostat housing) is reading about 1,125 ohms of resistance which is about 190F. This level of resistance matches the coolant temperature. The problem is the ECT on the Quadzilla reads 160. Disconnecting the two wire lead at the sensor seems only to affect the gauge on the dashboard and not what the Quadzilla is showing.
Where is the ECM or PCM pulling the ECT of 160 from? It does not appear to me it is from the sensor located at the thermostat housing. Is there another coolant temperature sensor other than the one near the thermostat housing?
Having the ECM think coolant temperature is 160 when it is actually 190 I think is affecting fuel consumption and maybe performance?
