- Replies 7
- Views 1.5k
JAG1 3 posts
jamman 2 posts
dripley 1 post
pepsi71ocean 1 post
Hello everyone,
I need some help determining what is happening here. I’m supposed to be taking my truck to WY in November, but this is a problem.
My truck has been running ok but it doesn’t get a lot of use these days. Over the summer, I barely started it so it had fuel in it from spring time. I tend to run 1oz/1gal of 2 cycle oil in the fuel. It is stock other than putting a different lift pump and fuel lines for the pump.
It has started and ran ok cold. I’ve fooled with this just a bit over the last couple weekends. I got in it and have lots of bluish/white smoke, but only after past it being cold. Today I started it and it was running ok cold. I jumped on the highway and ran it up to nearly 3k rpm just fine, over 70 mph, 2 miles down the highway and then 2 miles back. Parked it, ran inside to change clothes then came back out, started it and head out and started it’s sputtering and surging. I might be able to rev up over 2000 rpm, but then it’ll surge/fall back, surge/fall back, or then sputter, then lose power (while at full pedal) down to nearly 1000k rpm. Obviously, the smoke increases with this. On the highway, it seems bluer.
I have a video of revving and the smoke, all while sitting still. Maybe it’ll help you understand some of what I’m dealing with. https://m.youtube.com/watch?v=8SIM-ahqtIw
Now this is all after having issues 2 weekends back, trying to work on it last weekend, adding 1 pint of gasoline (last weekend) to a little over 15 gals of fuel in the tank to try and increase octane a touch (wondering if the 2 cycle might have settled by the intake, or gelled or fuel got old or something).
I can and am leaving it idling as we speak. No blue smoke at idle, btw. What I’m doing is trying to get the fuel level very low in the tank. I plan on putting in fresh fuel and probably some Seafoam just to clean injectors in case I’ve gummed things up. I had had a bit of a fuel leak from my fuel line feeding the injector pump after it left the lift pump. I need to tighten that.
Any ideas, guys? Suggestions on what to chase down? Do I have a lift pump issue? VP issue? Have I got a sensor gone bad? Have I got bad fuel and should see resolution with fresh fuel and a “cleaned out” tank?
Thanks in advance!
