Ok I have been trouble shooting a hard starting/long cranking issue for almost 2 years now, owned the truck since 2006
2001 24V HO
AIRDOG the week i brought it home and ever since
Edge Stage4 Jammers I think injectors
Newly rebuilt NV5600 (ChaCh$$$ng)
196K
nose downhill, no problems
level, takes over night
nose high, takes a few hours
to require a priming sequence necessary to start the truck, worse in the cold weather
Lots of informative helpful threads out there and I have been through them all
Last night pinched just at the VP44 inlet and just after the T return lines from the head and the VP44 and closed the lines
This morning it still would not fire until priming sequence
Where would the fuel be going?
Is this a sign of the VP44 going bad?
No codes stored
TIA
Joel
  • Replies 19
  • Views 8.4k
  • I have to agree with @Tractorman. The nose up/down thing is a red flag. It does not take much of a opening while pinching those lines to let air thru. I also curious what check valve you replaced on t
  • You might try loosening the nuts on the head at 1, 3, and 4. Prime the system then until you get a good flow of fuel to them and tighten them as they do, then keep cranking. It will run rough until al
So far...
checked all fittings for tightness and added extra fitting clamps or tightened
put system on air and visually checked all connections (nothing found)
replaced check valves at head and VP44
replace filters
trouble shot with pureflow tech support to eliminate airdog
pulled bed to inspect tanks and tank connections and air test fittings
Have not replaced o-rings so does that fuel or air leak into the head?
2 hours ago, joeld79 said:
...require a priming sequence necessary to start the truck, worse in the cold weather
Your info location says Seattle.  If in Seattle proper we haven't had low enough temps to effect starting...
yet imo.
Maybe I missed it but
How much Fuel pressure?  If you dont have gauge oriellys or auto zone has loaners that you pay for. Bring it back in 1 piece. Get $$$ back.  But so much info gained by knowing pressure, makes gauge very worth while.
Overall sounds to me like problem hard to find, but should be easy fix.
Depending on which airdog, easy to connect pressure gauge or at OEM filter cap.
Just for clarification, does this mean you are cracking open high pressure injector lines to get the engine to start?
I don't know that pinching off lines is a reliable test since you can't actually see if the line is completely closed off.
Did you use a soapy solution to check for the leaks?
I know that you are trying to resolve this, but many times fuel lines will leak air in, but not fuel out.  The fittings on the back of the head probably need to be taken apart and properly resealed.  I personally have never had trouble at that location, but many owners have.
Your symptoms do match fuel draining back to the tank, especially the nose parked up hill part.
- John
I have to agree with @Tractorman. The nose up/down thing is a red flag. It does not take much of a opening while pinching those lines to let air thru. I also curious what check valve you replaced on the back of the head. Mine has none, just the banjo blot connection.
The head and  return tee grommets were my problem many years back with those symptoms. About I year ago the same issue came up and I started growing oil about the same time. I changed out the injector o rings for the later and found a couple damaged connector tube o rings damaged and changed all of them also. No more growing oil or hard starts. My return lines were fine this last time.
So I rebuilt the return T with cummins washers and still had hard starts. I replace the washers for the fuel return line at the back of the head,  when i changed the banjo fitting at the head i could only find 1 washer as i blindly removed it.  Can anyone confirm the correct washer number?  Still having hard starts but even worse now with the new washers at the head.
Never mind
Edited by joeld779
@joeld779, I hope your problem is fixed when you get everything resealed behind the head.  I'm sorry, but I don't know the part numbers.
Some time ago I recall someone mentioning on one of these forums that he had similar symptoms and it turned out to be the input shaft seal on the VP44.  After awhile I think he figured out that fuel was leaking into the engine oil as well.  I hope this is not your problem.
- John
Try this 3963983. They are 12mm for 12v and 24v fuel system banjo bolts.
With the oil growing you might need some new o rings. Do you know how many miles yours have on them?
ya I used that exact part number I have 2 new ones on there, stage 4 jammers with about 100k
You could pull the valve cover znd have a look with engine running. You might can see fuel leaking around an injector. Maybe pull a couple and see if the orings have flattened out where they meet the bore.
Just went through this on mine. It’s been an ongoing issue for a while in the colder weather after the truck sat overnight. Never and issue when the truck sat at work for longer periods of time. I also had a tapper cover leak that I repaired. Truck was good for 2 weeks...... then.......
I replaced:
straight cut orings on the t fitting
o rings on the return line at the vp44
new return relief valve on vp44
new fuel line and fittings from lift pump forward- 15 psi idle
new filters on the fass
still hard a hard start that was worsening, noticed fuel in oil.
replaced:
injector o rings- were VERY flat and came out easy, real easy
new crossover o rings
seemed to solve the fuel in oil issue
then:
new #4 injector line- was leaking at head after initial injector o ring change
new crossover tubes from BD diesel and orings- figured it’s was best as they had 240k on them and been through 4 injector swaps
so far so good! Truck runs a lot better all around. Power is back to where it’s supposed to be. Happy till the next issue arises. I’m 99% positive the injector o rings were my issue. Only time will tell if the oil level rises again, then it’s time to dig a big hole and burry it.
figured i wasnt alone on this issue thanks for the info, gonna look at putting the stock injectors back in anyway, let me tell you the looks i get from all these tree huggers in seattle
If they have been sitting for a while..... they may be stuck. I tried installing my old fbd 100s that were on the shelf for a few years. Started up and ran on 4 or 5 cylinders. Wasted $30 in seals and orings. If the injectors are working in the truck now just replace the seals. Very easy. Do it sooner then later and do a few oil changes to get the diesel out of there
Ya they been sitting for 7 plus years, maybe ill order some rv's
So due to time constraints (single parent 2 kids) and against the advise given above I installed my old injectors.  They looked in really good condition and I need my truck back for work.  I primed the system via key bump 10-15 times and its starts to fire right away but then dies quick.  I repeated this 10-15 cycle of key bumps 3 times with same result.  Just curious if I should keep trying this sequence or if that is a sign something is stuck? TIA  IMG_20191120_200046.jpg.aa12e604429d765a94babc1fa26207ee.jpg
Edited by joeld79
pic
You might try loosening the nuts on the head at 1, 3, and 4. Prime the system then until you get a good flow of fuel to them and tighten them as they do, then keep cranking. It will run rough until all the air is cleared from the lines. Sounds like you are close to it starting.
I should add if your old injectors have a lot time on them they could be in a fairly worn state. Went thru this not long back with flattened orings. Swapped some older ones that were not flat onto the newer injectors and it worked fine until I could some new ones.
Edited by dripley
Got it fired up, I had the 1,3,4 injectors cracked but wasn't tightening them as they got fuel at first (derp)
Drove it around after letting it idle for a while and she rips!
No more dirty Edge injectors that looked like they'd been in about 12 different trucks and smoked like a chimney
Started her up this morning after sitting overnight and she fired up faster than a ***** in church
Thanks fellas!
Edited by joeld79
