throttle position reading
OK guys looking to what you guys have for throttle position percentage reading at 70 MPH cruise with 3:55 gears and 47RE trans thinking mine is a little high from what I can remember but I could be wrong mine is at like 24-25% at 70MPH cruise I thought was usually around 17% before just can not remember??? Thanks in advance reading from quadzilla adrenaline
Edited by 24vcumminspower
  • Replies 9
  • Views 1.5k
  • Fair enough. Next time I hit the highway I'll try to remember to have a look.   Edit: Next Post   Have you changed anything on your tune lately? For example, a drop in the canbus f
  • hdpwipmonkey
    hdpwipmonkey
    @24vcumminspower  24% to 26% at 70 mph on level ground.  I checked it on my way west and back east and it was the same both directions.
There are so many variable that can skew that number. For example, you could easily be at 17% with a tailwind, turn around and have a headwind and be more than 24%.
I agree but same route I take all the time with close to same conditions and flat ground
Edit: Next Post
Have you changed anything on your tune lately? For example, a drop in the canbus fuel percentage settings at the boost PSI range you cruise in would force you to use more throttle to get the same amount of fuel.
Edited by kzimmer
Clarification
OK well then engine load is right at same as TPS% if that is correct
I thought that is why the old comp tune was set to start fueling at 20% because cruising was usually under that %
